2005- 4.6 engine tick....blew a spark plug
I have the 2V 4.6 (150,000 miles) and basically concluded that my tick was the result of loud spark plugs and manifold leak
Turns out it was literally a ticking time bomb. The tick has probably been there for 2+ years
2 days ago I blew #3 spark plug out of the head and took the threads and coil pack with it. Most horrid noise I've ever heard a vehicle make.
Now the engine sounds brand new
I know this was an issue with previous models but don't see to many accounts of this happening on the NBS
So far this and clogged injector have been my only 2 engine problems
It doesn't happen very often, but there will be an occasional plug blowout with the 8 thread heads. This is why you should torque the plugs to 28 ft/lb instead of factory spec.
I hope you fixed it right with a Timesert.
