How to replace pinion seal 2004-2008
Old Apr 23, 2021 | 07:23 PM
  #31
Rick Montejo's Avatar
Over thought
Originally Posted by warrior150
does anybody know what I can do if I didn't mark or count threads? my 06 f150 with 9.75 seal was leaking so I pulled and put in new seal, but I pulled an idiot move and didn't mark it. am I totally screwed?
Seen this subject beat
​​​​​ to death.
Anyway, you're not screwed. It happens all the time. "Hey, my pinion seal is leaking" Go buy a new one and replace, right? I completely understand all the variables involved in a rear end. Pre-load, backlash, shims, tourque, math, etc... But! I talked to a mechanic that has done hundreds of Pinion seals... Don't get me wrong there is nothing wrong doing with all the pre tourque readings, measurements, etc... He, simply disassembles, replaced seal and torques pinion flange nut to 160 ft lbs. So, you're not screwed, proof is in the pudding and I have 350,000 on my 05 f150, 5.4 (which r supposed to suck, going for 500, 000&#128526.
Fl Keys to Maine, many times... Keep on truckn!
​​​​ measurements, etc...
