Moisture in fog lamp?
Old Apr 9, 2012 | 08:47 AM
Gord's Avatar
Unhappy Moisture in fog lamp?
I have a lot of moisture or consdensation inside he left fog lamp of my '05.
Anyone have it and what's causing it?
Old Apr 9, 2012 | 09:00 AM
dixie_boysles's Avatar
You may need a newe o-ring/seal on your bulb. If not, then the lens needs resealing
Old Apr 9, 2012 | 10:28 AM
Raptor05121's Avatar
^^ this and this. do you have the stock 9145 bulbs in it?
Old Apr 9, 2012 | 01:36 PM
projetmech's Avatar
i got that in my 05 when i had it also. it a started after i put in sylverstars. i took the bulb out and dryed up what i could with shop towel pieces on mechanical fingers and then blew some nitrogen in there until the rest dryed up. i then put some clear rtv around the bulb oring. problem solved. had the truck for a couple years after and never saw waterh in there again.
Old Apr 10, 2012 | 09:04 AM
Gord's Avatar
Yes, I do !
Old Apr 10, 2012 | 02:21 PM
I would check the o-ring around the bulb first. Then check the seal of the reflector bowl against the lens.
