Steering Wheel Removal
Old Mar 17, 2012 | 05:16 AM
04fxdwgi's Avatar
Originally Posted by mikeford
I think I need to add resistors am I right?
LED's usually run on anywhere between 2 and 3 volts depending on the LED. Hook em up to full voltage and they won't last but a half a second, sometimes completely blowing apart. If you send the specs for the LED, voltage and current, and what voltage your battery sees at 2000 RPM, I can tell you what resistor to use. Or you can purchase a "LED Driver module" and be done with it. The module provides a steady output voltage to the LEDs over a wide range of vehicle voltage conditions.
Old Mar 18, 2012 | 07:42 PM
07F150Lifted's Avatar
You Get 2 X 3mm LEDs And A 470 Resistor At 1/8 Watt And It's Fine I Did It An It's Exactly What It Needs
Old Mar 23, 2012 | 06:52 AM
Remove Buttons On Steering Wheel On A 2007 F150 XLT? The Cruise Control Buttons I Know How To Remove Air Bag/Horn. I Just Want To Know How To Remove The Cruise Buttons?
