Rear leaf springs
Old Feb 25, 2012 | 11:47 PM
4 da boat's Avatar
Rear leaf springs
I have a 04 with a 6 inch lift with a ad a leaf. Left side from top of the tire to the fender is 11.5 inches and the right side is 9.5 inches. A good two inch drop, what are my options ? I was thinking of getting stock Raptos spring and maybe loose the 4in blocks.
Old Feb 26, 2012 | 01:01 AM
tbear853's Avatar
Maybe I'm wrong .... but I think you'll loose load capacity with Raptor springs.
Old Feb 27, 2012 | 11:16 PM
4 da boat's Avatar
I thought the more leafs the better the pay load. I do like the idea of not having the 4 inch blocks.
Old Feb 28, 2012 | 01:35 AM
tbear853's Avatar
More leaves are stiffer when all else is the same, like width and thickness.
How many leaves on a Raptor anyway?
I thought Raptors had low weight ratings with less stiff but longer travel suspensions, like leaves with lower spring rates but more arch?
Like I said .... maybe I'm wrong? I figured more would have replied by now?
Old Feb 28, 2012 | 07:35 AM
Jmo371's Avatar
wait buy the factory raptor springs?...that cant be much different then getting Deavers built for you?
Old Feb 28, 2012 | 11:10 PM
4 da boat's Avatar
Has anyone else had a leaf spring fail ? Why is it better not to have blocks and go with the full arch ? Am not going to spend $1000+ or $. 250 for stock leaf but I would like to upgrade .
