Edge Evolution COMM GEAR question
Old Feb 20, 2012 | 07:26 PM
theduke308's Avatar
I have my edge showing the COMM gear that I am in. I am on stock tune just using the edge as a display. My question is what is the little lock symbol that shows up on it for. Mine shows up when I am driving about 45mph and lightly increase peddle pressure. It stays on there till the truck finally downshifts then goes away and once I let off it comes back. When I am putting a little pressure on the gas peddle the truck sort of vibrates a little while the lock is showing...whats the idea?
Old Feb 20, 2012 | 09:34 PM
sam1947's Avatar
It's the converter 'lock-up' symbol or overdrive
Old Feb 20, 2012 | 11:50 PM
Overdrive and converter lockup are 2 separate things. Overdrive is 4th gear in a 4 speed and 6th gear in a 6 speed.
If you are getting vibrations in overdrive and lockup when you accelerate slightly around 45 mph you may be having a low grade misfire, it's probably time for new spark plugs and/or coils.
Old Feb 20, 2012 | 11:53 PM
theduke308's Avatar
Changed all 16 of those things in October but to a misfire, this almost feels the same way only much more faint and subtle, its just enough you can tell its make a bump
Old Feb 21, 2012 | 10:07 AM
Have you ever had the tranny fluid exchanged?
Old Feb 21, 2012 | 12:30 PM
theduke308's Avatar
not since I have had it in October. The fluid is red/pink and does not smell burnt.
Old Feb 22, 2012 | 11:33 AM
Might want to get it done.
