140,000 plug change
Old Jan 16, 2012 | 08:26 AM
ZRXKUMA's Avatar
140,000 plug change
Changed the plugs on my friends 5.4L after 140,000 miles on the plugs. He had bought the removal tool prior to the attempt. 3 out of 5 broke, but the tool worked as advertised. Used grease on the removal threads and the threads showed no signs of wear after all was done. The gap was at .095 when we measured the old plugs, amazing it was still running. Also cleaned the throttle body and mass air flow while it was all apart, this was also pretty bad.
Old Jan 16, 2012 | 03:32 PM
tbear853's Avatar
Wow ..... glad to hear it went so well.
I'll bet that job woke up some beans in the old girl!
Old Jan 16, 2012 | 03:37 PM
Did your friend run any top tier gas or techron through the fuel system before the plug change?
Old Jan 16, 2012 | 05:13 PM
04heritagef150's Avatar
If 3 out of 5 plugs broke then I think you missed 3 of the plugs! Haha
Old Jan 17, 2012 | 10:02 AM
ZRXKUMA's Avatar
1) he ran SeaFoam through two tanks prior to the swap
2) Ops, Pennsylvania math strikes again, 3 of 8 broke.
Old Jan 17, 2012 | 10:20 AM
Angry
Yep....seafoam don't help.....chevron techron or Gumout with regane or berrymans b12 would've been far better.....hopefully you changed the oil afterward.....
Old Jan 17, 2012 | 09:11 PM
Buckeye2019's Avatar
So after the change how did the truck run?
Old Jan 17, 2012 | 09:20 PM
ZRXKUMA's Avatar
He said that the truck hadn't run that well in years. Oil changed afterwards.
