Help quick pleaseeee
Old Jan 15, 2012 | 08:49 AM
MRLSU2U's Avatar
Alright guys so yesterday I decided to totally rewire my amp from the battery/ground etc. This isn't the first time I've done this so I'm at a loss for my problem. After hooking everything back up (exactly the way it was before) my truck won't start. It'll turn over for days and days but it won't fire. I didn't mess with anything other than my amp (and I changed a blown #10 fuse, *trailer lights*) so I'm severly confused. I have a trailer full of furniture hooked up to the back as I was supposed to leave back to Daytona Beach this morning. Any helps appreciated so I can get on the road.
I must also add. I did pour some coca cola on my terminals as they did have a good bit of acid build up on them. I did the same on my terminal connectors which I also cleaned with a wire brush. My connection is solid. Everything works in and on the truck, she just won't fire... Also tried a jump start.. Nothing I even unhooked the battery overnight thinking a pcm reset might solve it... Once again nada.
Old Jan 15, 2012 | 09:10 AM
MRLSU2U's Avatar
Close thread please. Read up a little bit and i had to retrip my fuel pump switch. Fired right up
