will a jumpseat fit my tuck.. please i need advice!!!?!?!
Old 12-02-2011, 11:34 PM
boomer1's Avatar
Exclamation will a jumpseat fit my tuck.. please i need advice!!!?!?!
im about to buy a jumpeat with cupholder and starage that was in a 2008 xlt extended cab... will it fit in place of my plain jumpseat in my 2008 regular cab xl..please i need answer asap???? im thinkin it should work but idk
Old 12-03-2011, 12:10 AM
DSGSTX81's Avatar
If it is the console without the shifter, yes. That is the XLT console--the other is the Flow Through console--it will fit too, with a little work
Old 12-03-2011, 12:25 AM
boomer1's Avatar
its not the console its the jumpseat.. the middle seat in the bench seat!!!!!
Old 12-03-2011, 08:19 AM
DSGSTX81's Avatar
Whoops boomer--had a loooooong night last night lol. Yes, the jumpseat from the ext cab will fit, just dont think you'll have the wires in your truck to run the rear 12v power point like the SuperCabs have. Other than that, it's four bolts on the floor and they use the same bracket, so you should be in business. Sorry again about the confusion with my first post.
Old 12-03-2011, 11:46 AM
boomer1's Avatar
Haha man it's fine I no where ur comin from Lol and thanks for the input!!) and yea I know I don't have the wires but is there anyway I can wire it up to make it work?!?!
Old 12-03-2011, 01:29 PM
DanielWalker10's Avatar
as long as your old jump seat is separate from your passenger and driver seats, it will fit no problem. to remove your old jump seat, you will have to remove the part you sit on by grabbing the front of it and pulling up. after the seat is removed you will see four bolts, just remove those and pull your old jump seat out. reverse the process putting the new seat in and you will be on your way.
it's really not necessary to wire up the 12V hook up since you would probably never use it. but if you wanted, you would have to find a wire harness out of a truck that is equipped with it because it takes specific plug to give the outlet power if i recall correctly.
Old 12-03-2011, 01:31 PM
DSGSTX81's Avatar
Quick answer: Im not sure about harnesses or their availability at the dealer.
Longer answer: it wouldn't be practical, where it located stock but maybe you could move the 12v inside the fold-down console? That would be cool, and much more easily accessed.
Old 12-03-2011, 05:34 PM
boomer1's Avatar
thanks guys, so u gotta take the seat off the frame to get it off??? and ye ill prrly jus make a new on inside the console... but what would i wire it to???
Old 12-03-2011, 07:00 PM
Yes, just pull up from under the front of the seat cushion. Four T-50 bolts IIRC, and maybe one electrical connector but yours may not have that since it's a single cab. I know the screw and scab have the electrical connectors.
Old 12-04-2011, 10:40 AM
i'm assuming you already have two 12V outputs just as my regular cab. if not, quit reading now. If you do already have two, and those aren't enough you need to consider hardwiring some stuff. adding one to your console would be a waste of time, money and energy plus risking hacking up your new console. and you have to remember, if you drill a hole inside the compartment you will be making a hole exposing your seat cushion. it would be hard to find a place to make a hole with enough depth for your wires and the outlet itself..
Old 12-04-2011, 03:53 PM
boomer1's Avatar
Is rlly like I use the 12v on the jumpseat. Do u all no where I can get the harness
Old 12-04-2011, 04:12 PM
DSGSTX81's Avatar
I have played around on Ford Parts Online and not come up with anything yet. Best bet is to talk to your local dealership and have them check their parts catalog. With your truck being an XL, there were probably no factory provisions set up for such a swap...just talk to your dealership and let us know...
Old 12-04-2011, 10:36 PM
boomer1's Avatar
yea i mean i no there will prry be anything factory but do u think i could wire it up myself..
Quick Reply: will a jumpseat fit my tuck.. please i need advice!!!?!?!
