Any ideas?
Any ideas?
I have the 8200 gvw truck.. I know this has ben discussed, but not sure if it has been looked into.... I want a lift, all the kits say excluding my truck.. Well Rancho is only about 8 miles from my house. I called and they said the ONLY reason that it's excluded is because they have never tried to install one on a 7 lug truck due to the dealer usually not having one available for trst fitting... So being the good person I am I offered mine..
He said he would love to try it but in Monroe Michigan they only do shocks...
Now for the question... Does anyone know of a reason the 4 inch kit WOULDN'T fit??? I would buy it if I could find someone that would try to install it..
.........Now for the question... Does anyone know of a reason the 4 inch kit WOULDN'T fit??? I would buy it if I could find someone that would try to install it..
I would think it would fit. Only real difference is the 8200 gvw trucks got the bigger rear axle housing w/7 lug axles and 7 lug front hubs. Why don't you throw a leveling kit on the front and get some 33's on the stock wheels and call it a day. The money it will cost you to be the ginea pig is a lot of coin, especially if it don't fit.
Some more info I have collected as to why the lift SHOULD work.. The spindles (steering knuckles) are the same on my truck as the regular F150... The hubs are different but you don't get hubs with the kit... The back axle as most of us know is bigger on the 8200. Thinking bigger u-bolts will fix that... Starting to think this will really work..
