"Growling" at high speed?
Old Nov 7, 2011 | 09:51 AM
4.6 Punisher's Avatar
Anyone ever get a loud "growling" type of noise from the rear end at 95+ MPH? I don't know if it's my wheels/tires or the axle work I had done last year.
Old Nov 7, 2011 | 10:55 AM
Brad Johnson's Avatar
That growling your hearing is likely your driveline saying "back off or I'm outta here". That's what happens when you combine a long and relatively thin-walled driveshaft with a 4.30 gearset. Any minor imbalance or flex in the shaft, or imperfection in a bearing or ujoint, will quickly make itself known, usually right before it enters Dynamic Disassembly mode.
Brad
Old Nov 7, 2011 | 11:19 AM
StoveTop's Avatar
Brad
...and at 95+ mph. Geez man, keep it under 80!
Old Nov 7, 2011 | 11:23 AM
Brad
So do you think it's mostly the driveshaft, or the combination of the gears, lowering shacks, and the OEM driveshaft?
I lol's at that
It's only on the track. Scout's honor
Old Nov 7, 2011 | 11:57 AM
Driveline angle changes, higher driveline speeds, a slight misalighnment in the diff - any of those could cause vibration at speed. It's one of those things that's tough to diagnose without actually riding in the truck.
Take it to a reputable driveline shop and buy the shop manager a cup of coffee to drive around the block with you. Maybe they can get you pointed in the right direction.
Brad
Old Nov 7, 2011 | 01:26 PM
Brad
It only does it when it's close to 100 MPH, so he might want more than a cup of coffee.
Old Nov 7, 2011 | 02:21 PM
malexander52's Avatar
Lmao
How do you get them to troubleshoot for this?
Punisher -"I am going to need you to find a long, dark street..."
Shop - "Why's that sir?"
Punisher - "Cause it only happens over 95mph"
Shop - "Really? I am not sure if we can accommodate you..."
Punisher - "Well what ever you do don't keep it at 88mph for too long, I don't know 'when' you will end up...."
Shop = "Security please come to the front."
Old Nov 7, 2011 | 02:56 PM
60DRB's Avatar
...my old '73 chevy 4x4 with 4 bald tube type tires wandered a bit when above 90 too. Maybe the're related? Seriously?
also LMAO
