Remote Canister Filter kit ?
Old Nov 6, 2011 | 01:48 AM
evil05f150's Avatar
What do you guy's think about this setup for a 2005 5.4L ? Yes it is costly $380
This CM Remote Canister Filter kit is for 3/4-16 thread standard gasket size (apox 2-5/8") spin-on filter applications. This kit gives you everything you need to install a CM canister oil filter. The kit contains a billet remote CM oil filter housing, a CM high flow fine filtration filter element, a 90 degree rotating billet aluminum block adapter, 8 feet of stainless steel braided hose and all of the necessary fittings.
8 MICRON OIL FILTER
Old Nov 6, 2011 | 08:05 AM
Dog'em's Avatar
why ?
Old Nov 6, 2011 | 09:19 AM
54regcab's Avatar
For $380 there are other mods I'd rather do.
Old Nov 6, 2011 | 12:35 PM
budmur's Avatar
Since almost every modern engine can go 200,000 to 300,000 miles with just occasional maintenance, I think it's overkill.
Old Nov 6, 2011 | 03:31 PM
fatty4x4's Avatar
Is this a simple install? I would consider it if it was and went on sale. Honestly I find the location of the oil filter a bit of a pain to get to. I do use the K&N oil filter with the nut to make it a bit easier. I also use the futo drain valve.
Old Nov 7, 2011 | 08:19 PM
evil05f150's Avatar
Originally Posted by Dog'em
why ?
to eliminate the pain & mess of changing the stock oil filter
and i used a cheap one before on my old focus & it blew apart shooting all the oil out and blowing the motor .
Old Nov 7, 2011 | 08:40 PM
If you would stop using Fram filters, you wouldn't have that problem. If you want to use a remote, use a remote kit that takes a stock Motorcraft spinon filter like the older trucks had.
Old Nov 7, 2011 | 09:00 PM
evil05f150's Avatar
it wasn't the filter it was the remote mount where the line went into it broke & blew the line off. I use K&N filters
