Help with drivline "clunk"
Old Oct 31, 2011 | 02:02 PM
dasher108's Avatar
I am hoping to get some ideas from everyone as to what this might be. The scenario is this;
  • 2007 fx4 scab
  • Newly installed edge programmer
  • Truck running smoothly (pre-trip)
I volunteered to help my bro move from Edm to Vancouver Island. I pulled a 12 ft u-haul trailer packed to the hilt! The drive is a bit of a challenge with the mountain passes, I really tried to take it easy with some of those pulls up the hill.
After I dumped my bro and his junk for a turn n burn I noticed that my truck now makes a clunk (sounds like right under my feet) everytime I start it up. Everything seems to running fine, no codes no engine lights, just this dam clunk when I turn the key to start the truck???
Thoughts...
Leon
Old Oct 31, 2011 | 03:21 PM
MossyOak3006's Avatar
Does it do it when you crank the engine up or just when you turn the battery on?
Old Oct 31, 2011 | 03:23 PM
dasher108's Avatar
It does it when I crank the engine...
Old Oct 31, 2011 | 11:08 PM
dasher108's Avatar
but it does not do it everytime..?? Seems not to have any pattern as to when it happens, sometimes yes and sometimes no??
Old Nov 1, 2011 | 05:38 AM
Jetpilot2's Avatar
Mount/s, (motor or tranny)?
Maybe have someone look under there while you crank it and see if they can see/hear and pinpoint the problem.
Old Nov 1, 2011 | 07:52 AM
Jetpilot2's Avatar
I forgot to mention, there are tons of threads about "driveline" clunks, but yours sounds like a different issue. Most of the others are when they start rolling (slip yoke) or turning (differential).
Just food for thought.
Old Nov 1, 2011 | 10:20 AM
mkinttrim's Avatar
X2 on the mounts
Old Nov 1, 2011 | 11:22 AM
dasher108's Avatar
Good suggestions, I will give them a try after work. To add to the description;
The sound happens when I first start the truck after it has been sitting for awhile. I will start the truck and hear the clunk while I am cranking, however if I stop the struck and start the truck right away there is no sound?
