Power Steering Fluid
Old Oct 25, 2011 | 08:51 AM
enggass's Avatar
Hey all,
It feels as though my steering wheel has gotten a 'little' stiffer when turning so I thought I'd check my Steering Fluid. What I found was that it is about 1/4" below the 'Min Level' in the reservoir. Would this effect how the steering feels or should I look for something else? Also, what brand of PSF should I get if going to AutoZone? I don't think they carry Motorcraft...
Thanks,
Steve
ETA: 2006 Lariat with @54,000 miles on it.
Old Oct 25, 2011 | 09:54 AM
fatty4x4's Avatar
Oil your steering shaft knuckle. Im sure there are pics on this site somewhere.
Old Oct 25, 2011 | 10:06 AM
enggass's Avatar
I just went to get some steering fluid and noticed that the wheel does not spin back to center as freely as it did after taking a turn... ???
Old Oct 25, 2011 | 12:53 PM
enggass's Avatar
Found the problem... Steering Shaft U-Joint. I am covered under an ESP so it will cost me $100 deductible. Was told it is around a $300 part - $500 bill with labor. Yikes... Also read on here on another thread I could have soaked it with lubricant to temp fix it...
Old Oct 25, 2011 | 12:54 PM
You don't use PS fluid, you are supposed to use Mercon V ATF. Check your owner's manual!
Old Oct 25, 2011 | 12:57 PM
enggass's Avatar
What would using PSF instead do?
Old Oct 26, 2011 | 01:40 AM
Dunno, but it's not the right stuff.
