driver side window will not go down and up but motor is running
Old Oct 13, 2011 | 08:32 AM
YOMAN's Avatar
Hi,
Driver side window wont go down or up. I can feel the motor is running when i press button down...something loose in the door panel?
Is there a link to tell me how to remove door panel and inspect, fix it before i might damage it
Its 2004 supercrew FX4
Thanks!
Old Oct 13, 2011 | 09:55 AM
kevhead75's Avatar
Most likely it is the regulator. This is a known problem on these series of trucks. I have replaced 2 on my 2004. Usually the window will just fall into the door unexpectedly but I had one that would grind up and down and then finally quit working. Roughly a $100-140 part from tasca or team ford in vegas. It's fairly easy to take the door panel off in these trucks to check it out. Do a search on window regulator and you find how-to's.
Kev
Old Oct 13, 2011 | 09:57 AM
04lariat711's Avatar
Hey I actually just fixed the exact same problem in my 04 lariat. Basically my window regulator had a snapped cable that runs from one side to the other on the bracket but nothing was wrong with the motor. I just went ahead and changed the whole regulator. Bought a new one on ebay for about 60 dollars with shipping. There are a couple very detailed threads with pictures on removing both the door panel and the regulator itself. Just use the search option. Hope this helps
Old Oct 13, 2011 | 01:47 PM
o4eFeX4's Avatar
Had this exact thing happen on my old Explorer. Shouldnt be hard to replace.
Old Oct 13, 2011 | 04:51 PM
YOMAN's Avatar
Thanks..
Window is not falling down and I tried move it down with my hand and it's very firm hold and won't moving...
Maybe something stuck..
I'll do that over the weekend.
Old Oct 13, 2011 | 08:45 PM
RUSS04's Avatar
Originally Posted by YOMAN
Thanks..
Your window regulator is toasted. I had mine replaced a month ago.
Old Oct 14, 2011 | 10:08 PM
Flash69's Avatar
LIke everyone else said. The regulators in these trucks SUCK!!! They are cable driven and the cables like to snap.
I went with OReilly's parts because they are cheaper and have a lifetime warranty.
Old Oct 15, 2011 | 02:40 PM
UCF-150's Avatar
It's not the cables that snap, there is a swaged end on the cable that goes into a plastic retainer. The plastic retainer cracks and the swaged end pulls out. I've replace more than I can count.
Old Oct 16, 2011 | 03:35 PM
YOMAN's Avatar
Got it replaced by myself with your help and link.
It's now back to normal
Thank you for all your help!!!!
Old Oct 16, 2011 | 04:12 PM
estey07's Avatar
My driver side window in my 07 F-150 goes down just fine....but when I try to put it up....it goes up very very sloooow....extremely annoying...any ideas on what I should do??
