05 FX4...wet floor
05 FX4...wet floor
Hey everyone....having a problem with passenger side carpet getting wet...im in michigan so i know its not the a/c drain tube....havent had the a/c on in awhile....ive done some searches on here....most common problem was the third brake light leaking....mine is good there...headliner is dry...back seat is dry....and just as a precaution i pulled the third brake light off and ran a bead of silicone around the weather stripping.....a few people had mentioned something about one of the body seals behind the dash.....anyone by chance have fixed that leak b4 and maybe have a few pics of it? or if anyone has any other ideas on where else i should look for it leaking......thanks in advance...
My passenger side carpet gets wet after I go through puddles. It just started happening at the end of last winter. I am still confused on how it is happening because I have gone through quite a bit of water before and it never happened... I just try to avoid puddles for now.
thought i would update this thread i started....was having big problems with passanger side carpet getting soaked when it rains....was checking everything i could...couldnt narrow down where the water was coming in.....so for the hell of it i siliconed where the windshield meets the top of the roof just in the corner.......after the soaking rain fall we had all day yesterday here in michigan....carpet is bone dry!! sucks to have to do something like that on a vehicle thats only 6 years old...but it worked...
Im in the same boat as you 07 fx4 wet pass side carpet when it rains. I pulled the carpet and found its leaking from somewhere on the firewall in the middle of the floorboard. But I cant figue out where,
hey boss . if drain is cloged up , is da drain hose on pass side?? tkx .I wll tryda tomorrow is 33 f. here in VA. now cooooldd.
