searched but no luck, werid 4x4 problems...
I found many links on this, but none like my problem. ok, so the day after i bought my 05 4x4, i try the 4x4(i know stupid)....It didnt work. So i took it back in and the were nice enought to fix it free of charge. They said it was just a small electrical part. So i tested it after and it worked perfect. now about two weeks later, i just went into the hills and was going to do some muddying and noticed that when it was in 4hi no lights came on but seamed to be in 4wheel. When i went in to 4lo the light would come on and i could feel in was in 4wheel. Any help would be greatly apperciated. Thanks
Todd
Todd
Thanks for the help.
I had a problem kind of similar to that. my 4x4 hi wouldnt work, but my 4x4 low would. It turns out that my 4x4 low actually wasnt working. It would sound and feel like it was in 4x4 low, but it actually wasnt. It would "slam" into 4x4 low and everything when I would "put" it in 4x4 low, but it really wasnt in 4x4 at all. try going on some dirt or gravel and spin the tires just to double check that the 4x4 low is working.
If the shift motor on the transfer case is sticking (happens a lot, especially if not used very often) you can try tapping on the shift motor with a hammer handle and see if it will then go into 4HI. Same way we used to "unstick" starter solenoids sometimes. Since you say the light bulb is working-...the 4HI light won't come on if the shift motor doesn't actuate. Could be the shift motor is bad.
