Jerking Motion problem?
Old Sep 12, 2011 | 03:25 PM
Nismo Racing's Avatar
Angry Jerking Motion problem?
I am having this jerking motion problem with my truck, I had a few times before I left at around 70 mph. let off the gas, then return the gas, to feel this nice jerk/ thud my truck made. Anyone know what this problem could be and whats the fix for this?
Old Oct 17, 2011 | 01:44 PM
still having this problem any solution or idea to fix this problem with the jerking that would be great. thanks!
Old Oct 17, 2011 | 02:52 PM
Electron-Jack's Avatar
Sounds like the torque converter lockup system. You might want to pull your negative battery terminal for a while to force the computer to relearn. Then go out and get on a nice stretch of road where you can get up above 70MPH and then let of the gas and let it coast down to 35MPH and then do this again about 3 times. If that doesn't work I got rid of the same issue on mine when I programmed it with the Edge programmer.
Old Oct 17, 2011 | 03:36 PM
Yep a pcm reset might do the trick......hopefully......
Old Oct 17, 2011 | 05:21 PM
02SC4x4's Avatar
this sounds like a slip yoke problem as well.
you can try greasing it. others have said it works and some say it only cures it for 2 weeks.
