Brake controller placement
Old Oct 6, 2011 | 02:09 PM
f150skidoo's Avatar
In the next couple of days im going to install a brake controller into my truck and im wondering of a different placement for the unit besides the the usual place by the obd 2 port.
Old Oct 6, 2011 | 02:20 PM
Which controller are you installing?
Old Oct 6, 2011 | 07:33 PM
f150skidoo's Avatar
Its a Draw-Tite activator 2
Old Oct 6, 2011 | 09:17 PM
90454SS's Avatar
Just my 2 cents, put the controler in a place for easy access. I got into trouble last year on a switch back on a mountain road and would have lost it if it was for being able to lock the trailer brakes up. And no I didn't have too much trailer it was all my fault going to fast on an unknown road will steep blind turns.
Old Oct 6, 2011 | 10:45 PM
f150skidoo's Avatar
Ya you obviously want a controller in easy access, but has anyone put the controller in the open bottom compartment in the center stack?
Old Oct 7, 2011 | 08:24 AM
Micheal's Avatar
Do you have the center console like on a fx4 or lariat? I have mine mounted to the side off it. Looks pretty good. I will try to get pictures tonight when I get home and post them.
Old Oct 7, 2011 | 10:48 AM
f150skidoo's Avatar
I do have a center console but it does'nt flow through to the dash i have space between my center console and dash.
Old Oct 7, 2011 | 03:54 PM
90454SS's Avatar
I tryed mine in that hole in the center stack but it stuck out and didn't look good. Now if you cut a hole and flush mounted it, it may look alot better. I mounted mine to the left of the steering wheel on the bottom panel. I figured it would get in the way but I haven't hit it getting in and out of the truck in the last 2 years.
Old Oct 7, 2011 | 06:40 PM
avfrog's Avatar
Mine is under the dash on the left side of the steering wheel.
Old Oct 7, 2011 | 09:17 PM
Neil's Avatar
25 Year Member
I installed my Tekonsha controller under the dash on the right side of the steering wheel.
Old Oct 15, 2011 | 07:31 AM
Rotested's Avatar
I mounted mine inside the FX4 center console. Granted, in a pinch it would require the extra step of opening the console to manually activate the trailer brakes, but, in all my years of towing, I have never needed to. Plus, for the other 99% of the time a trailer with brakes is not attached, it is out of sight.
Old Oct 16, 2011 | 03:28 AM
code58's Avatar
IF I needed it, I sure wouldn't want to have to open the console to get to it. A friend was towing a trailer down a long grade late at night when the trailer suddenly started to weave and if he hadn't had quick access to the controller, it would not have been a pretty sight. Something you probably rarely ever use, but when you need it, you need it NOW! When I did tow a travel trailer, because I'm right handed, the controller went above my right leg on the bottom of the dash.
Old Oct 17, 2011 | 04:17 PM
yz85rider2002's Avatar
ive got mine on the left side of the steering wheel for ease of access
Old Oct 17, 2011 | 07:19 PM
avfrog's Avatar
Tekonsha p3!
