4x4 FX4 Issues
Old Jul 31, 2011 | 11:09 PM
DixieNormous's Avatar
guess ill be returning that thing lol...i guess ill go to the dealer and buy the hub assembly part that moves the gears in and out...maybe they're not being moved far enough and slip? this is starting to be a very annoying buy
Old Jul 31, 2011 | 11:34 PM
transfercase's Avatar
Originally Posted by DixieNormous
yeah still coming to a stop in 4wd and when i give some throttle it becomes under load and then feels like its about to do the pop...try not to do it in fear or doing even more damage.
I still think it's an IWE thing. Like maybe they aren't fully grabbing. Does this happen when you are in 4wd on dirt/lose gravel where the tires can spin?
Old Aug 1, 2011 | 07:48 AM
Honestly never even turned 4wd on while on dirt yet....haven't even been on dirt yet...but is imagine it wouldn't matter....I'm going buy mote jack stands and get all 4 wheels up and really see what happens...granted won't be under load.
Old Aug 1, 2011 | 11:44 AM
60DRB's Avatar
DN, have you gone through the two links previously posted? The first one "everything you ever wanted to know..." is a good trouble shooting guide. Driving the truck with the 4WD engaged on dry pavement is NOT good for the 4x4 driveline. It sounds like a vacuum/IWE issue to me as well. Not hard to fix once identified.
Old Aug 2, 2011 | 10:32 AM
Yeah actually before joining I did a good bit if reading here and another forum. I know its not good for the system to drive on pavement, but just did it this one time...even on pavement it shouldn't pop like that or drive so rough though...trying to find jack stands right now to get all 4 off the ground and see if I can pinpoint the POP..
Thanks for all the replies! Keep them coming, ill update as I work on it.
Old Aug 4, 2011 | 01:40 PM
Anyone happen to know how far the gear is supposed to move out to lock the hub when 4wd is engaged?
