2 issues!!!!
2 issues!!!!
Hey guys, truck is an 07 screw cab 4x4 34000 miles. My ac box under the dash has a TON of condensation on it and it's dripping a little bit in my floor board! Normal? It's coming out of undercab drain fine! Also steering wheel has a weird sound when turned off center on highway speeds. like line pressure or like sand shifting? Noise is hard to explain!! Haha hope all is well! ~Kennedy~
You don't say where you're at but if you're someplace like GA or FL or some massively humid place where you can just grab some air with your fist and squeeze and water comes out, yeah, you'll get condensation on anything that's below ambient temps.
No idea about steering wheel though.
Tsb for the ac drain....
Click link>>>http://ww2.justanswer.com/uploads/fo...SB_07-13-5.pdf
Also they're might be another tsb on the steerin linkage....
