Spark Plug Problem
Old Jun 20, 2011 | 10:07 AM
transfercase's Avatar
Up until early 08. It really is not that big an issue if you take it to a dealer that knows how to get them out. Or, most guys that follow the TSB explicitly, don't have that big a problem. It sounds as if the OP soaked them in carb cleaner the night before and they need to be soaked about 30 minutes prior to working them out. That way, the carb cleaner does not dry out and give the carbon time to set some what. Occasionally, there is the one that is going to be a hassle no matter what.
I thought about this as a problem as Central Texas has been 103* so maybe a lot of of it evaporated. Either that or they broke when I did the 1/8 of a turn before soak which is possible. Glad that i got them out, the lisle tool is really an ingenious idea.
Old Jun 20, 2011 | 10:38 AM
Yep, the Lisle tool is our savior!
Old Jun 20, 2011 | 10:42 AM
Using an impact also helps....
Old Jun 20, 2011 | 10:45 PM
Dan_J's Avatar
Glad you got them all out.
Old Jun 21, 2011 | 09:05 AM
motorking's Avatar
HT plug removal
See the video at autolitechallenge.com/pro
Motorcraft and Autolite have now released HT plugs with an improved stregth shell to prevent this from happening.
Old Jun 22, 2011 | 11:38 PM
sam1947's Avatar
More info on this please ...... Thanks
Old Jun 23, 2011 | 06:44 AM
motorking's Avatar
High Thread spark plugs
Not much to say, 3 months ago, Autolite and Motorcraft released a better design higher strength shell. If you follow the installation instructions and use these plugs, you will never break another one. All Motorcraft/Autolite plugs now on the shelf are the new design. Here is an installtion video I made
http://www.youtube.com/watch?v=2Gz5Pd-hrWQ
If you want to earn prizes for watching it, watch these three and answer the questions
