The little stick at the bottom of the tailgate...
What is its exact purpose? Is it part of the spring assisted lift?
That "lil stick" is rubbing on my newly acquired Recon white lightning tail light bar. I want to grind off about half an inch of it so that it doesnt rub anymore.
I seriously doubt that it will harm anything. But just want to make sure
Any thoughts??
Any thoughts??
Not sure what it is or does, but I removed mine with no side effects. It unscrews with a Torx T-25 or something like that. I think I removed the tailgate to get to it. Be very careful not to scratch/dent the tailgate if you remove it.
Are you talking about the "stick" on the right side of the tailgate? I believe that is there to prevent the tailgate from just falling off if you unhooked the restraining cables from the bed. Otherwise the tailgate would just fall off when lowering without the restraining cables
There are a few other members with the light bar installed - see what they have done to alleviate this. Or better yet, contact the MFG.
