Squeaky suspension maybe?
Old May 9, 2011 | 01:18 PM
bigdog87's Avatar
Lately, every time I go over a bump or something of that nature, there is this obnoxious squeaking noise that is driving me nuts. I thought perhaps it was in the rear shocks? So I jumped up and down in the bed and nothing.. Perhaps it's the front shocks? Loose bolt somewhere? Any ideas? This afternoon or tomorrow morning I'm going under with some grease and going to check all bolts and possible squeaky areas, and lube them well.. Any ideas, similar problems would be GREATLY appreciated! Thanks!
Old May 9, 2011 | 02:13 PM
jmt0645's Avatar
its your front ball joints
Old May 9, 2011 | 04:07 PM
bigdog87's Avatar
Thank you, going to grease them up good tomorrow.. Any idea where in particular?
Old May 9, 2011 | 05:11 PM
If they're the original stock ones they're probably the sealed.....you can use a grease gun with a needle and puncture the boot and fill them.....but if they have been dry for awhile they might have been worn....your best bet is to replace them......the replacements will come with a grease fitting....
Old May 10, 2011 | 11:37 AM
jmt0645's Avatar
MOOG's tend to work best for me
Old May 11, 2011 | 09:51 AM
bigdog87's Avatar
Thanks guys, going to try the grease first.. Then if it still doesn't work, I'll have to replace them eventually.. but after just putting 710 dollars in brakes few weeks ago.. I gotta hold off!
Old May 11, 2011 | 08:32 PM
lowblueranger's Avatar
My truck would squeak over speed bumps. I thought it was a ball joint up front or something in the rear. This went on for about 3 months before I started hunting it down. It turned out to be the tailgate!! A little spray oil on the latches and its silent. I couldnt believe the tail gate was the culprit.
Old May 15, 2011 | 09:59 PM
ONAMISSION's Avatar
Same thing goin with mine, been thinking about the ball joint replacement, let me know how it goes.....
Old May 15, 2011 | 10:05 PM
x2!
Glad to hear you got the brakes. Did you have the brakes done or do them yourself? If so, how did the rear brake shields look? When they rot out some they squeak when you hit a bump, and thats the only time you can tell that is the problem unless you visually see rust around the mounting bolts.
Old May 15, 2011 | 10:49 PM
bigdog87's Avatar
x2!
Had them done, no idea.. The squeaking had been happening before I got the brakes done. Still haven't made myself go out their to hunt down the sound.. hopefully one day this week.. Keep ya posted.
Old May 18, 2011 | 12:22 PM
outdrsmn80's Avatar
I've got a similar problem but it's not when I hit bumps. It squeaks when I first drive off in the morning. I don't set the e-brake and I'm not on the brakes when it does it. It's only for about a second first thing in the morning. Any ideas?
