What Is The Difference Between These Two Models? Please Help!
Old Apr 15, 2011 | 06:17 AM
mike1990's Avatar
Hi, I've been looking for an F150 for quite some time and I finally found the exact model , color and everything I wanted, but the guy ended up selling the truck already. But I Came across alot of F150's, but they look different to me. So I was wondering if you guys could tell me what's different about the exterior of these two trucks.
Apart from the wheels , tires , running boards , leveling kit
but if I were to add the same wheels , tires , running boards and leveling kit would it look the exact same as the 4wd one? I wasn't sure cause the exterior just looks different on each one to me for some reason. The reason I'm not just waiting for a 4wd is cause I've been looking for months now and I've yet to find one that I Like or they are usually out of my price range
Heres The Link To The one I Wanted that was sold
http://i53.tinypic.com/4rxaur.jpg
http://i56.tinypic.com/21j2jc5.jpg
Heres the one I was interested in, to see if I could make it look like the one above ^^
http://omg.ly/02Eg
So basically I'm just asking what's the difference with the exterior between the 2wd's and the 4wd's? Are the 4wd's bigger?
Old Apr 15, 2011 | 07:08 AM
roush9799's Avatar
Bodywise, there's basically no difference.
Old Apr 15, 2011 | 08:04 AM
08stx4x4's Avatar
A 4wd sits 2" higher from the factory than a 2WD. The 4WD has longer struts in the front and lift blocks between the axle and leaf springs in the rear.
Other than that there's no difference other than a 2WD not having a transfercase, front drive shaft, and front Differential.
