just died
Old Mar 12, 2011 | 12:28 PM
Bandit22's Avatar
just died
While leaving a stoplight my 04 f150 with edge evo just died now all it does is say check gauges and a flashin red light on top of the dash everything works but it wont turn over any ideas
Old Mar 12, 2011 | 02:32 PM
Meatwagon's Avatar
Flashing red light is the passive anti-theft system (PATS).
My guess would be an issue between the Edge and PCM. Somehow the PCM lost its hex info. Were you doing anything with the Edge just before then? Also, what is your location and current outside temperature?
Old Mar 12, 2011 | 03:22 PM
Bandit22's Avatar
I am in Ohio temp was bot 30 and no I wasnt touching the edge was just driving to work
Old Mar 12, 2011 | 04:27 PM
Wrong. The only time the edge communicates with the PCM is during a program change. Other than that it's a gauge pod.
Old Mar 12, 2011 | 04:29 PM
OP, where do you live? Hard to troubleshoot things when you don't fill in any vehicle/location info.
Old Mar 13, 2011 | 05:30 PM
mkosu04's Avatar
you say it "won't turn over"... it won't even crank? Or it will crank but not fire?
If it will crank but not start it could be the fuel control module
If it won't crank it must be electrical... does your Edge pod still display? Pull up the voltage reading and see what your battery is saying.
Old Mar 13, 2011 | 08:05 PM
Meatwagon's Avatar
... that's where I was getting to. OP didn't says whether or not he performed any programing in his original post.
Old Mar 14, 2011 | 11:26 PM
Bandit22's Avatar
no programing at all was driving to work and my location and truck info is in a post above and it does not do nothing dont crank no turnover just check gauges and fast flashing red lite on the dash
Old Aug 20, 2011 | 12:00 PM
twinvalley's Avatar
Hey did you find a solution to why your F150 would not start my 04 F150 is doing the exact same thing. Died on me would not crank or turn over found a big hole in the fuel pump module replaced it and still will not crank it has a flashing red light on dash if help would be appreciated. Just wondering
