RV towing
Old Mar 5, 2011 | 09:23 AM
orpannie's Avatar
RV towing
I want to tow my 2007 F150 V-6, manual transmission behind my motor home, but can't find any information about what needs to be done to tow it safely. Does anyone have any suggestions?
Thanks!
Old Mar 5, 2011 | 10:01 AM
avfrog's Avatar
^ Use the search engine here. I am pretty sure there have been a few threads about this.
Old Mar 6, 2011 | 12:22 AM
What does your owner's manual say?
I think the 2wd with manual transmission can be towed as is in neutral (obviously).
Old Mar 6, 2011 | 02:50 AM
2004Triton5.4's Avatar
If it's a 2wd about all you will have to do is disconnect the driveshaft.
Old Mar 6, 2011 | 03:50 AM
code58's Avatar
If it's a manual, why do you have to disconnect the drive shaft???
Old Mar 6, 2011 | 09:27 AM
poptop's Avatar
no need to disconnect the driveshaft. will you be using a towbar or a dolly. my thinking is a dolly would tow better. that way the trucks steering won't interfere with towing.
Old Mar 6, 2011 | 10:03 PM
wyattboche's Avatar
You could put the truck on it with the rear tires on the dolly and lock the steering wheel. http://www.campingworld.com/shopping...tow-dolly/1683
