Engine fail safemode
Old Feb 3, 2011 | 11:43 AM
jalichoacan's Avatar
Hello all, This morning, for thesexond time, my truck stopped in the middle of the freeway. I would give it gas, but it was as if te truck was off. the display read "engine fail safemode". I then pulled over to the aide to turn off the trauck and turn it back on,(since if happened before, I knew
what to do). Why could it be? any help appreciated.
truck is a 2006 5.4 supercrew 4x4
Old Feb 3, 2011 | 11:52 AM
My truck did this and the code indicated that the Throttle Control Motor was deactivated due to a dirty throttle body. I cleaned the throttle body and no more problem.
Old Feb 3, 2011 | 11:57 AM
MGDfan's Avatar
Old Feb 3, 2011 | 12:02 PM
Justin_w32's Avatar
Mine did this 3 times, twice completely shut off, and once no power dead gas pedal. Turns back on and runs fine.
Old Feb 3, 2011 | 12:10 PM
thanks guys. I will clean the throttle body.
Old Feb 3, 2011 | 08:22 PM
05BlackFX4's Avatar
Mine did this as well.
Clean the throttle body and replace your TPS (throttle position sensor). Mine hasnt done it since. Would randomly do it every 2-3 months in all driving conditions. It finally did it getting off the freeway and thru a CEL. Got it fixed the next day for cheap.
