Is this normal??
Old Jan 26, 2011 | 10:10 AM
THE_SHOW's Avatar
Is this normal??
Changed the fuel filter, fuel module was replaced under warranty and new air filter
It ONLY does it at WOT 40-50mph around 5000 on the tach it hits a dead spot and then picks back up. Went to the dealer and had a tech drive my truck cause its DRIVING ME NUTS!!!! He drives it and tells me that its normal? REALLY???
I have an MBRP XP exhaust and K&N drop in filter.
thanks for the help
Old Jan 26, 2011 | 10:42 AM
mdhawkin's Avatar
Originally Posted by THE_SHOW
At WOT 40-50mph around 5000 on the tach it hits a dead spot and then picks back up. Went to the dealer and had a tech drive my truck cause its DRIVING ME NUTS!!!! He drives it and tells me that its normal? REALLY???
thanks for the help
Since you did not say you have a programmer, I am going to have to say that's you transmission shifting. The dead spot is due to the time between the gears when the clutch packs are slipping and not fully locked up.
Old Jan 26, 2011 | 10:49 AM
THE_SHOW's Avatar
so.......the programmer would fix this?
Old Jan 26, 2011 | 10:55 AM
mdhawkin's Avatar
Yes, you can adjust the needed parameters to speed up the shift, and allow it to shift at a higher rpm (among other things). The reason for the slower/softer shift is for comfort mainly. The gryphon I have made a world of difference and thats only with the canned tunes. Eventually I will get around to custom tunes.
Old Jan 26, 2011 | 11:58 AM
thanks for the help
A programmer with CUSTOM tunes will help....
SCT or Gryphon
