diff fluid questions.
Old Jan 16, 2011 | 04:15 PM
fivespeedsteed's Avatar
my 60k maintanance is coming up. im gonna do my fuel filter, t case fluid, trans filter, and probably my diffs.
the diffs dont have an interval on them. the manual says for the rear synthetic 75-140. ill probably get mobil 1 for that. then the front just says premium rear axle fluid 80-90. my jeep was like this, took syn gear oil in the rear, and non syn in the front.
should i just put 75-140 syn mobil 1 in the front and rear? or do the 75-90 or whatever it is synthetic mobil 1 in the front? or just go with normal old 80-90 in the front?
also, i need to get the ford friction modifier. it says to do 4 oz of the ford stuff in the rear, its best to get this from ford right? the stuff i sell at advance is 7 oz of trans x additive for limited slips, but thats too much isnt it?
also, i did the trans filter and fluid at 50, cause it had never been done, im gonna do it again at 60k so i can get it onboard my 30k intervals. it was decently dirty at 50k, theres no harm in doing it again is there? what is the torque spec on those bolts, they werent on there pretty tight.
thanks guys.
edit: sorry
this is a 07 lariat 5.4 with a RP 8.8 front and 9.75 rear axle with the 3.73 limited slip.
Old Jan 16, 2011 | 08:18 PM
I would put synthetic 75W-90 in the front. That is an acceptable substitute for 80W-90 conventional. 75W-140 is too heavy.
Yes, get the modifier from Ford. It's not that expensive.
Old Jan 17, 2011 | 04:17 PM
poptop's Avatar
or you can get royal purple 75w140 syn at pep boys and it already has the modifier in it.
Old Jan 17, 2011 | 06:51 PM
is it the right ratio?
Old Jan 17, 2011 | 07:22 PM
I'd rather have the Ford-specific modifier in there. Maybe I'm just too picky.
Old Jan 17, 2011 | 08:39 PM
j-edge's Avatar
i kept ford modifier and went amsoil 75-140 for rear its cheaper than mobil one and better from what ive heard. ams 80-90 front
Old Jan 17, 2011 | 08:55 PM
is there any decent brand i can get online for a better price than the mobil 1? anyone used the wallmart syn gear oil or is that not a good idea?
Old Jan 18, 2011 | 06:00 AM
lomo2surf's Avatar
i am in the same boat as u brother - I am looking at Lucas on amazon
http://www.amazon.com/Lucas-10121-75...=pd_sbs_auto_2
Old Jan 18, 2011 | 08:40 AM
so then this
for the rear and this
http://www.amazon.com/Lucas-10047-75...=pd_sim_auto_2
for the front?
Old Jan 18, 2011 | 08:42 AM
Walmart syn is fine, it meets specs.
Old Jan 18, 2011 | 05:53 PM
so general consensus for the front is that full syn 75-90 is fine for the front, and 75-140 is good for the rear?
Old Jan 18, 2011 | 06:00 PM
lomo2surf's Avatar
Originally Posted by fivespeedsteed
thats what I am going with ... never heard anything bad about lucas oil
Old Jan 18, 2011 | 06:01 PM
atxfx4's Avatar
I'm about to change out the diff fluid on my FX4 as well. I was wondering what the volumes were that I should be filling. Does anybody have that off hand?
Old Jan 18, 2011 | 07:10 PM
capacity for them? if your truck has a 8.8 front (it should) and a 9.75 rear, (vs an 8.8 rear, or a 10.25 rear) then the front takes 1.85 quarts and the rear takes 2.75 quarts. and remember if you have a limited slip (axle code on door sticker starts with a letter not a number) then use 4 oz of ford friction modifier first, then fill it with gear oil.
Old Jan 18, 2011 | 07:17 PM
60DRB's Avatar
Why would the fluids be different in the front and rear differentials?
Would the friction modifier (4 oz.) volumes be the same even though the total fluid volumes are different?
weird for both items...
