Broke 1 of 8 plugs
Old Jan 14, 2011 | 02:35 PM
chrisrud15's Avatar
Broke 1 of 8 plugs
First 3 came out no problem. Number 4 turned like it was stripped. Pulled out the top with needle nose and the bottom part stayed in. Next 4 came out perfect. My buddy went to grab the Lisle tool so hopefully it works. 66k miles. Pics to come.
Old Jan 14, 2011 | 02:48 PM
The Lisle should work for you.
Old Jan 14, 2011 | 05:05 PM
chrisrud15's Avatar
Lisle worked perfect. All back in and running perfect. Fixed the miss I had. I'll post pics later tonight. Plugs looked pretty rough and only had 66k miles on them
Old Jan 14, 2011 | 06:23 PM
Meatwagon's Avatar
Did you follow the TSB, run SeaFoam and/or Techron, or your own variance of these methods?
Old Jan 14, 2011 | 06:39 PM
chrisrud15's Avatar
Broke them loose with a ratchet with engine warm. Soaked them with Chem Tool for an hour during lunch. Came back with impact wrench with no problems. Couldn't use impact wrench on back two and the back driver side was the only one that broke. It's a PITA to get with tool. Impact wrench is the way to go. I dont think soaking them had much benefit IMHO.
Old Jan 14, 2011 | 08:14 PM
risupercrewman's Avatar
It seems as if the impact wrench gives good results from what I have seen here! I think that it is the constant presure that the wrench provides to work the plugs loose, & break away any carbon once the plug starts spinning......
Old Jan 14, 2011 | 08:31 PM
Irish FX4's Avatar
I agree. When i did mine i thought the same thing.
All 8 of mine came out but they gave a good fight and squealed like a pig all the way out.
Old Jan 14, 2011 | 08:38 PM
Big Slick's Avatar
for those that used the impact, what sort of attachments did you use? my friend has a cordless impact that accepts hex shank tools, but i seriously doubt i'll find any sort of attachments that will let me use the extensions, sockets and universals that i'll need.
Old Jan 14, 2011 | 08:48 PM
sam1947's Avatar
What did you use for the replacement plugs ??
Old Jan 14, 2011 | 09:09 PM
TJL442's Avatar
There are hex drive to 1/4 in. bits available for those type of impacts, then you could use adapters up to 3/8. Should be able to get one at a hardware store of Home Depot/Lowes. I have an 18V Dewalt with that drive that I am going to try. I don't know if that will have the torque required or not as I haven't done any plugs yet. But if you can get the adapter its worth a shot unless someone else has tried with less than stellar results. Just thought I would throw that in there.
Tim
Old Jan 14, 2011 | 09:25 PM
chrisrud15's Avatar
I replaced them with the revised plug Motorcraft SP515 from the original SP507. Here are the pics.......
You can see they look pretty bad for 66K miles. But I'm glad only one broke and my misfire is gone. Feels like new again.
Old Jan 14, 2011 | 09:28 PM
chrisrud15's Avatar
Old Jan 14, 2011 | 10:12 PM
sam1947's Avatar
'Milwaukee Tools' has a set of drivers that has a 3/8" square drive in it at Home Depot, don't know if it is sold separately as a single driver though.
Old Jan 14, 2011 | 10:55 PM
savagemonte's Avatar
Tim
I used a Dewalt cordless impact and a 1/4'' hex to 3/8'' socket on my plugs.
I started with a hot motor, and hit the trigger in the forward then reverse and didn't stop till i felt the plug spin freely. The back two i had to break loose with a ratchet then put the impact on them, and they came out fine, i didn't have one plug break.
I had 104k on my truck, so i would recommend the impact meathod.
Old Jan 14, 2011 | 11:39 PM
bankrpt's Avatar
I have this electric impact you think this will work or is it to big? Also please explain your procedure to removing them with a impact thanks
http://www.craftsman.com/shc/s/p_101...2_00917090000P
