Broke 1 of 8 plugs
Old Jan 15, 2011 | 01:43 AM
The SP507 is actually the improved single platinum. The SP515 is a double platinum. The original plugs are no longer available.
Old Jan 15, 2011 | 08:15 AM
bankrpt's Avatar
Yes the sp507 is available advance auto has them
Old Jan 15, 2011 | 08:59 AM
Big Slick's Avatar
what's revised about them?
Old Jan 15, 2011 | 09:01 AM
Big Slick's Avatar
Originally Posted by TJL442
There are hex drive to 1/4 in. bits available for those type of impacts, then you could use adapters up to 3/8. Should be able to get one at a hardware store of Home Depot/Lowes. I have an 18V Dewalt with that drive that I am going to try. I don't know if that will have the torque required or not as I haven't done any plugs yet. But if you can get the adapter its worth a shot unless someone else has tried with less than stellar results. Just thought I would throw that in there.
Tim
Thanks. I'll look for the adaptors.
Old Jan 15, 2011 | 09:46 AM
TJL442's Avatar
Originally Posted by savagemonte
I used a Dewalt cordless impact and a 1/4'' hex to 3/8'' socket on my plugs.
I started with a hot motor, and hit the trigger in the forward then reverse and didn't stop till i felt the plug spin freely. The back two i had to break loose with a ratchet then put the impact on them, and they came out fine, i didn't have one plug break.
I had 104k on my truck, so i would recommend the impact meathod.
That's great to hear. I have to get mine done soon when I put the supercharger on. The truck is just a few miles short of 40K so hopefully I have good luck with it but I guess I will see. Thanks for the input on the Dewalt.
Tim
Old Jan 15, 2011 | 03:14 PM
The ground shield is more cut away at the tip and the sleeve is slightly smaller in diameter to help minimize carbon deposits.
Old Jan 15, 2011 | 03:45 PM
chrisrud15's Avatar
Just make sure you put some antiseize on the new ones so they come out smooth next time
