will 35s fit?
Old Jan 13, 2011 | 08:59 AM
ukcats5's Avatar
will 35s fit?
i want to go with 35x12.5x20 toyo open country mt and rockstar 20in wheels. will they fit with a 2 1/2 in leveling kit??? or will they fit with a 3in body lift? 2005 f150 4x4 crewcab
Old Jan 13, 2011 | 09:58 AM
GA4x4Screw's Avatar
35's should fit with a 2.5" kit, but you might have to trim a little off the front so the tires don't rub when turning. with a 3" body lift, they should defintely fit (with a leveling kit already installed obviously lol)
Old Jan 13, 2011 | 10:06 AM
Titan357's Avatar
I dont think they would fix a 4X2 even with a level, 33's are about the limit on them I think.
I can fit 265/275 fairly sure, but not a 285. (idk what 275 is in terms of 30/32/33)
Old Jan 13, 2011 | 10:46 AM
GA4x4Screw's Avatar
Titan he clearly said a 4x4 lol
But yes, you can only fit 33's on a 4x2
Old Jan 13, 2011 | 04:03 PM
slodsm's Avatar
What is the offset on the wheels? If +30 or so, probably be ok with minor trimming and a leveling kit. If -12 get the hacksaw out because it's going to take some work. With the body lift you'll still probably have to do minor trimming with a -12.
Old Jan 13, 2011 | 09:01 PM
Intimidator317's Avatar
315-70-17
17" mb wheels chrome gunner 6...w/25mm offset
fat bobs 3" level kit
very minor rubbing at almost full lock...not to mention the loss of 2 mpg...
Old Jan 14, 2011 | 07:52 AM
Titan357's Avatar
oops, my mistake.
Old Jan 14, 2011 | 09:05 AM
ScottFF00's Avatar
No they will not fit with just 2 1/2 inches.
Old Jan 14, 2011 | 12:42 PM
GA4x4Screw's Avatar
yes they will. my friend has a 2 1/2 kit on his truck and has 35x12.5 mud grapplers on it. they fit just fine
Old Jan 14, 2011 | 01:42 PM
ScottFF00's Avatar
Well go throw a 2 1/2 inch leveler on your truck and then 35's.....they do not fit. As others have said, you will have to trim along with the leveling to make 35's fit, plain and simple. The classic "my friend" story.....
