Air bag light came on any ideas?
Old Jan 7, 2011 | 01:16 AM
artgarcia's Avatar
Hi! I have a 2004 with 194,000 miles the air bag light turn on for Somoza 20 30 min and then turn off. Later turn on and keep one since 1 week ago. Any ideas? Thanks!
Old Jan 7, 2011 | 10:16 AM
JurassicBob's Avatar
2005 with 55k... same truck... Silver/DSG FX4... my airbag light has been on for a few months now.
Old Jan 7, 2011 | 11:33 AM
One of the impact sensers probably went bad.....
You're going have to take it to someone who can diagnose air bag issues....
Old Jan 7, 2011 | 12:03 PM
mkosu04's Avatar
Yes, and NO
When you first start the truck the light should flash in a sequence... count the flashes (watch for short and long pauses) and then post them on here.
The sequence tells you which sensor is bad.
Read this post
https://www.f150online.com/forums/20...then-back.html
Old Jan 7, 2011 | 12:11 PM
transfercase's Avatar
I had this happen last summer. Turned out it was the driver seat belt was giving a faulty warning to the airbag computer. I believe there is a pyrotechnic inside the seatbelt that forces the seatbelt to lock and that is what was not functioning correctly. They replaced the seatbelt and it worked. The work was actually done under warranty because the truck was under 50k. Appearanlty the airbag warranty goes for more miles than the standard warranty.
Old Jan 8, 2011 | 12:04 AM
artgarcia's Avatar
I just found i have 24 code number. Do you know what it means?
Old Jan 8, 2011 | 12:50 AM
I can't find a 24 in the LFC (lamp fault code). I assume you got this number from the flashing airbag light...
Old Jan 8, 2011 | 02:20 AM
artgarcia's Avatar
Hi Transfercase! thanks for your respond. I got the code with the flashing airbag light.
Old Jan 8, 2011 | 04:53 AM
System Disarm Failure or Internal Diagnostic Monitor Fault
Old Jan 8, 2011 | 03:20 PM
artgarcia's Avatar
Question
Originally Posted by glc
24
First, thanks for your info, now
What !!!! Any idea how to troubleshot and fix this error code?
never hear that code before
Old Jan 9, 2011 | 02:57 AM
Not a clue. Real specific, isn't it?
Old Jan 9, 2011 | 09:38 AM
zx12-iowa's Avatar
I had air air bag light. Turned out it was the very front air bag sensor bolted in front of radiator. The winter salt had corroded it to the extent of it brakeing apart.... Was $50 part at dealer and took all of 2 mnutes to install.
Old Jan 11, 2011 | 11:50 AM
artgarcia's Avatar
Thanks zx12-iowa! I just chequed the sensor and looks fine good gold plated contacts. Do you know the fail code in your truck?
