Painted headlights and night shaded fogs
Had this week off so I decided to give it a shot. I figured worst case, if they were messed up, I could get the recon projectors.
Removing the headlights and fogs was simple and straightforward.
Got everything ready and let the lights sit inside before applying heat.
I followed an instruction on here and put a piece of cardboard under the light in the oven. I would NOT recommend this. Either my oven is much hotter than the other or there was something on the cardboard. It produced a great smell (sarcasm) that filled the house for hours. Luckily, my wife was at work. I did the remainder of the work with the light sitting on an old baking sheet.
The lights are finally apart. If I were to do this over again, I would remove more of the old sealant as it posed some problems upon assembly later.
Here it is after assembly. I used the nightshades on the reflector and Krylon satin black on the headlight. I let this sit for about 18 hours before removing the strap.
Here is a nice before/after comparison
Overall, I'm happy with the results but there are a few things I would do differently the second time around. The next step is a recon smoked led 3rd brake light and red smoked led tails.
I did mine and they don't shine any brighter than the turn signals LOL. Maybe when I get HID's in my fogs too they will be brighter. The factory bulbs have a coating over the tip of the bulb blocking the light. The painted buckets don't reflect much at all.
I got a chance to test out the lights today and the fogs are way too dark. No big deal though as I don't use them anyway. The light output is pretty good for the silverstars though.
x2, could be the pics.
