O5 Power loss, no codes, no clogged cats~...stummped
Old Dec 8, 2010 | 10:37 AM
Crstfr's Avatar
hey guys... man.. .... i'm just having a hard time~.... truck has 115k, 2 payments left.. no warranty.. just upgraded stock shocks to the ranacho quicklifts, and 9000's in the back.. had the upper controls, all the bushings , linkages in the front done.... 2 weeks after that..rack/pinion went out....replaced that.... thought all this was a clogged muffler, . so i hacked it off.. nope~.... out 70.. new muffler.. took it to a shop up the road.... said everything was fine.... so they took to a tranny shop.. same thing... fine.. .. so i'm having them change all the tranny /differential fluids.......got the new muffler on.. dynomax bullet 3'., with a 3' turn down..... again i' pick it up today.. from the shop.. more money......
any ideas..i read through some other posts... o2 censor??.. but again.. no codes... i have a programmer, intake.... ... its a 4x4 5.4l, 3.55ls... and run hard~...
i'm lost guys.... if i get it back today and it runs the same.. .. grrrrrr...
HELP!!!
Old Dec 8, 2010 | 11:03 AM
You might want to check your fuel pump driver control module......its located on the frame cross member in front of the spare.....Ford mounted it directly to the cross member causing crap to get stuck inbetween....then the back side of the box corrodes away exposing the electronics......just a thought.
Old Dec 8, 2010 | 04:42 PM
Crstfr's Avatar
yeah i've read about that.. and seen pics on this forum of people that had to replace it.... i mean if its "going bad" would this be a sign?... .. i'm assuming if it is bad, the truck wont start.... no gas~.. right?
thanks for your input
call from the tranny shop says i was low on tranny fluid, and when the pan was dropped it looked like it never been cleaned~... grrr so that was cleaned, and so new fluides in the diff...... we'll see.. on my way to pick itu p... hope it was all that~..
Old Dec 8, 2010 | 05:23 PM
Big50's Avatar
If that doesn't fix your issue, more details on the power loss would be helpful. Does the engine sound the same? Have you changed the plugs?
Old Dec 8, 2010 | 05:41 PM
Windsor's Avatar
I agree power loss doesn't give an accurate account of what your truck is doing and when. Give details of when the "power loss" is occurring, what rpm, what gear (if it's specific to a gear, if it clears up at higher rpm, etc. Have you gotten a dealer to attempt to pull codes. Not all programmers can do the job adequately.
Old Dec 8, 2010 | 06:27 PM
SuperSlabCab's Avatar
How about your fuel filter. I read some time back, that other forum members were replacing theirs, and noticing power improvement.
Old Dec 9, 2010 | 09:08 AM
Crstfr's Avatar
got it back...... runs better.... i had the tranny and diff done~.. i think that was the trick guys..... seems to be getting back to normal.. i programed back to stock... just to see if it throws codes... which iits probably not.... my tranny filter was black!.. tranny oil... black!!..grrrr.... diff's never been done~.... fluids fluids fluids..... i've had the tranny flushed at the quicklube, but just not the same~....
thanks guys... i thik i'm back in business!!!.....1200 left then she's mine!!!
oh and stock tune sucks..... it was to go through the gears so fast, and put you in the lowest~..grrrr.. ..
Old Dec 9, 2010 | 10:58 AM
Better start saving for a rebuilt tranny...........
Old Dec 9, 2010 | 01:01 PM
X2....
Old Dec 9, 2010 | 01:51 PM
Crstfr's Avatar
Originally Posted by 88racing
X2....
bite your tounge.. its xmas~..... .... she's pullin and running strong again~.. .i'll meet that day when it gets here!
thanks for the help!
Old Dec 9, 2010 | 02:06 PM
Old Dec 9, 2010 | 02:48 PM
What can I say? Tranny fluid just doesn't turn black all by itself........
Old Dec 9, 2010 | 04:24 PM
Crstfr's Avatar
man your right about that~..... i'm the sucker..... grrrrr.. . .
live and learn~... 2 payments.....she's a hoss!
