Driver side door controls not working
This morning I discovered that the controls on my driver side door quit working. No windows or door locks. They work on all the other doors. The keypad on the door works so the door is getting power. hopefully its just a fuse. Anyone solve this problem before? where should I start?
if they work on all the other doors, i wouldnt imagine it being a fuse. Only makes sense that the keypad is on a different feed than the rest, because its hot even with key off and not using the acc. delay relay. I know the violet wire problem fixes some...but i dont know if it has anything to do with pw/pl. Is that is all thats wrong??
I severed a wire in the post area-during a stereo installation-and repaired it. The driver's control is instrumental in the operation with the other controls. Is the plug seated?
Start there.
Start there.
Later in the day everything was working fine. Maybe something was loose? I don't know. Could have been that in a Black Friday shopping stooper I was just imagining things. As long as it keeps working I'll just leave it be for now. Thanks for the help though.
Happened again today. It seems that if I open the door a certain amount (the notch before full extension) then sometimes the control panel won't work. There must be a loose wire or connection in there somewhere. I'll have to investigate a little more when I get a chance.
I tried pulling the rubber cover off of the wires. I seperated it from the door, but I couldn't see much in there. From what I can tell the wires are encased in another layer of runner or something. I didn't want to pull on it too hard for fear of causing more damage. Any suggestions, or a picture of what exactly I should be looking for?
------>https://www.f150online.com/forums/4387471-post8.html<------
check out the top 2 pictures i posted. there you can see the severed wire. Its in plain sight tho...your saying you cant really see anything
If not the wiring its the buttons. All my window controls were doing the exact same thing. I was in getting new tint and my shop guy told me he knew exactly what it was and had them all fixed in 15 minutes.
It seems that the underneath each button where the metal portion makes a connection to the metal on the door controls(if that makes sense) there was a build up of carbon or something that was stopping the connection. He popped out all the buttons and sanded down all the little metal portions that make a connection to the door controls and HOLY CRAP they all worked.
Didn't see mblour's thread but this is exactly what was happening to mine
https://www.f150online.com/forums/ar...ow-switch.html
I pulled back the rubber seal and cut a little of the extended piece on mine and sure enough the black ground wire is nearly severed. Crap.
Now how do I fix this? Get a piece of wire (any special kind or guage) and then just use 2 connectors to fix it up? This is going to be a real bitch because there's not much room to work in there. Any EASY way to get the door to open a little more? Or is there a trick here besides having to have baby hands?
Use a gauge that is at least as large or larger than what the original broken wire is. It's probably 14Ga. I would go down to at least 12Ga. if you use the wire from an electronic store. The bigger ones have bulk and will sell you whatever you need.
