07 Screw Wait To Start Light Stays on
Old Nov 18, 2010 | 09:34 AM
BaggedFX2's Avatar
While driving into work this morning the "wait to start" light on the dash came on and stays on. Thirty minutes later I turned the truck off and restarted but the light came back on again. I can't seem to find this issue in any of the other threads so I am hoping someone out there may have an idea of what to do. I have an 07 F150 Screw 5.4L. Any help would be much appreciated!!
Old Nov 18, 2010 | 12:41 PM
06 So Comfort's Avatar
Isn't the "wait to start" light a diesel thing?
Old Nov 18, 2010 | 02:54 PM
fivespeedsteed's Avatar
yeah there is no wait to start light in my truck.
Old Nov 18, 2010 | 03:14 PM
Titan357's Avatar
That means you need to wait to start that extra diesel engine you have.
Its not ready yet, or fully installed.
Why would a F-150 that has a gasser have a WTS light? thats like trying to change the spark plugs in a diesel.
Old Nov 18, 2010 | 03:47 PM
iHellFire's Avatar
Yea are you sure you posted in the right section? Only diesel engines have the little coil symbol or the "Wait to start" light....this is because the glow plugs are warming up so the engine can turnover easily. Gasoline engines do not have this because they use spark plugs.
Old Nov 18, 2010 | 03:54 PM
NCSU_05_FX4's Avatar
Originally Posted by iHellFire
Yea are you sure you posted in the right section? Only diesel engines have the little coil symbol or the "Wait to start" light.....
Apparently he posted in the right place...
I wonder if he means the Check-Engine-Light?
- NCSU
Old Nov 18, 2010 | 03:57 PM
Stu486's Avatar
Originally Posted by NCSU_05_FX4
I wonder if he means the Check-engine-light?
ex-diesel owner?? check engine light turns off...then you start....
Old Nov 18, 2010 | 04:00 PM
iHellFire's Avatar
If it is a little yellow engine symbol then yea go to Autozone or your local auto parts store and they should just plug there little computer in and will give you the code
Old Nov 18, 2010 | 04:02 PM
Stu486's Avatar
check pics...has an evo, use that to check for trouble codes
Old Nov 18, 2010 | 04:27 PM
you shouldnt need to wait for that to go off before you start it just put the key in and go. it will go off if there are no codes after its started
Old Nov 18, 2010 | 04:29 PM
Stu486's Avatar
saying it stays on...really need a pic of this mysterious light
Old Nov 18, 2010 | 06:54 PM
BaggedFX2's Avatar
Ok... mystery solved! I installed a US Speedo stainless gauge overlay back in the spring and it was originally designed for the FX4... the DTC locations on the new gauge overlay do not match the ones on the OE. Fortunately, I kept the old one and compared the location of the "wait to start" and it matched the "low tire pressure" light on the OE gauge overlay. Go figure! Easy fix and I'm back on the road! Thanks for your replies!
Old Nov 18, 2010 | 07:10 PM
fatty4x4's Avatar
So you have to wait to start it until there is air in the tires?
Who knew....
Old Nov 18, 2010 | 08:01 PM
Average-Joe's Avatar
LOL wait to start tires.
Old Nov 18, 2010 | 08:04 PM
Stu486's Avatar
can we get a sticky out of this??
