Leveling kit going on tomorrow
Old Nov 14, 2010 | 11:11 AM
sparkyb34's Avatar
Originally Posted by powerz69
Looks good! What setting did you put the ring at on the shocks?
They are on the highest setting. The front is about 1/4" higher than the back.
Old Nov 15, 2010 | 10:48 PM
sparkyb34's Avatar
pics with tires on will be up tomorrow
Old Nov 15, 2010 | 11:07 PM
powerz69's Avatar
How hard was this to do? Did you follow something or just jump in there? Did you change struts before? I have my bilsteins but nobody wants to install them for me. I have all the tools to do it, just never did struts before.
Old Nov 16, 2010 | 05:51 PM
rcebowl's Avatar
Struts are really simple to do ... there are a ton of DIY's online for spring/strut swaps.
A quick google search and a 12 pack and you should be all good.
Old Nov 16, 2010 | 08:30 PM
sparkyb34's Avatar
It is really straight forward to do. Take wheel off, unbolt to of strut (3 bolts), undo bottom bolt of strut (1 big bolt), undo lower tie rod. Remove whole assembly, compress spring, remove upper shock bolt, remove top of strut assembly, install new shock, and install. The hardest part is getting the new shock in there. It helps to have and extra set of hands. It took me and my brother 1hr per side. He did his truck the night before so he new what to do so no instructions for me. I would say give it 2hrs per side if this is your first time. It is not bad at all, the spring compressor was what i was worried about. Just use an impact gun on it and take it slow and do both side evenly. Shouldn't be a problem.
Old Nov 16, 2010 | 08:32 PM
sparkyb34's Avatar
here it is with new tires cooper zeon ltz 275/60/20
Old Nov 17, 2010 | 12:37 AM
WILDMAN442's Avatar
Very nice man!
Looks awesome
Justin
Old Nov 23, 2010 | 02:13 PM
sparkyb34's Avatar
Update, had the leveling kit and tires on for a while. The ride is slightly rougher than stock, nothing bad. The tires are nice, little hum going down the road, can drowned out with the radio very easily. The tires work good in the rain, can't wait to test them out in the snow. All in all I am very happy with the setup and how it rides and handles.
Old Nov 23, 2010 | 02:19 PM
mdhawkin's Avatar
Good update, truck does look good!
