Help: Drive Shaft Center Bearing Busted Through!!!
tbear, I decided to go with the new driveshaft from Driveshaft Specialist. I've had it a couple weeks. It was working well the first few times driving it. Now it is making a noise again. The noise goes away after a few miles. I don't know if it is because of the cold weather or because it wasn't greased properly or something else. Thanks for your posts.
Update:
The noise went away shortly after.
The new driveshft from Driveshaft Specialist of Texas has been on my truck for almost 2 years now with no problems.
If you need one of these, here is the link for more info:
http://www.driveshaftspecialist.com/truckhtml/ford.html
