Broke my blue fuel filter clip, help
Old Nov 1, 2010 | 09:07 PM
Texan Aviator's Avatar
Can I get one from autozone? They said they don't have any.. I'm reading some posts from a few years ago that say I need to buy a new line!? Others say a Zip tie works fine. I'm headed to Kansas in two days for a hunting trip no time to order a part.
Old Nov 1, 2010 | 11:30 PM
F1504.2's Avatar
You need P/N 7L3Z-9S317-B if you have the 3/8 " line. You may have the 5/16" and I don't know the part number this. I paid less than $10 for five of them (pink in color). Link below might help.
http://www.clipsandfasteners.com/For...e_p/a21127.htm
Old Nov 1, 2010 | 11:37 PM
F1504.2's Avatar
Found the 5/16" line P/N:
Ford Fuel Line Clip Fits 5/16 Fuel Line 7L3Z-9S317-A
Old Nov 1, 2010 | 11:46 PM
Thanks! After some searching I found this part number through autozone 800-015.. Clips made by "dorman" Anyone know if these work? I needs a backup plan in case for is out tomorrow. Short on time.
Old Nov 2, 2010 | 07:08 PM
Blang's Avatar
When I broke mine, I used a old white clip, cut the clip flush to fit inside the fuel line, then zip tied it so it couldn't fall out. Has been that way for over 3 yrs now. I just cut the ziptie to remove filter then install a new ziptie
Old Nov 3, 2010 | 12:51 AM
fivespeedsteed's Avatar
napa makes a neat kit the you cut the fuel line and use the barbed connector to give you a new clip. worked great for me.
Old Nov 18, 2010 | 08:13 PM
Ranger131's Avatar
How did you break the clip? You are supposed to use a fuel line removal tool on ***** sides on the filter. And yes that includes the fitting with the blue clip. The clip is not to be removed from the line.
Old Nov 18, 2010 | 11:49 PM
I was removing it improperly.. Ended up taking it to a local shop for a free oil change and they had a clip.
