2 versions of '06 rear brake pads? Which do I need?
Looking to buy some Wagoner thermo quiet pads for the rears, to match the fronts I just installed. Looking at the listed part #'s, there are two:
MX1012 (to 03/06/06)
MX1012A (from 03/06/06)
My door jamb sticker gives 3/06 build, and looking at the left cam cover, it shows an engine build date of, you guessed it, 03/06/06!? Mine has the little "price tag" build date sticker in the fuel door, but it is unreadable.
So, logic would suggest to me, the engine was probably built at least a day before the truck was assembled, so I probably need the latter, MX1012A part. But I want to be sure.
Any one know anther location to find chassis build dates, or know the physical differences in the two brake pad versions, that I can check to see which I need? From the online stock pics, the two versions show a slight variation in the anti rattle spring, which mine don't really look like either of those.
Help?
Old pic:
Help?
Old pic:
The way you read it is any truck with the build date up to and including 03/06/06 needs the MX1012 pads. Any date after 03/06/06 needs the MX1012A.
If your still unsure, buy both, match them up and return the ones you don't need.
BTW, always go by the door jamb sticker.
Yes, I understand that. But, I don't have a way to figure out the exact build date of the truck. The door jamb sticker only lists month and year. It could have been built on the 6th, or a few days later, according to the engine date...I have no way of determining that, and was wondering if anyone had a resource to help me.
