Upgrading Shocks/Struts on a Body Lifted F150...advise
Old Sep 16, 2010 | 11:44 PM
edgespeeder06's Avatar
I bought my truck with what I believe is a 3" Body Lift and 2.5 Leveling Kit with 33's. The suspension on it is something I want to do upgrade but I can't do a complete suspension lift upgrade anytime soon.
I was debating getting shocks for Body Lifted Trucks like the ones Rancho makes.
I want to make sure I am getting the right ones based on my lift as well
http://www.gorancho.com/shock_lookup...tems&x=47&y=15
I just need some advise as to if anyone else has done this. I do know my current ones have to go because the truck bottoms them out quicker since its lifted or maybe with 65k they are already bad as well.
Thanks!
Old Sep 16, 2010 | 11:53 PM
buckshot85's Avatar
a bodylift shouldn't affect the shock height. and OEM shocks should fit a leveling kit.
Old Sep 16, 2010 | 11:58 PM
Oh I Know but I just can't stand them bottoming out anymore. I was even looking at this to replace the leveling kit:
http://www.bilsteinus.com/leveling/index.php
Either that or I just have a few bad shocks that are thunking now
Old Sep 17, 2010 | 12:28 AM
alex7191's Avatar
you could for sure use some new shocks at 64k. if i were you id replace the leveling kit with bilsteins
Old Sep 17, 2010 | 08:00 AM
I figured....lol so Blisteins is definitely top notch to the rancho kit that I liked because it was red and white? :P I need to find out which will work with my
3" Body Lift and if I get rid of the 2.5 leveling...I can adjust the blisteins to fix that.
Old Sep 17, 2010 | 08:13 AM
MUD DIGGER's Avatar
yeah but bilsteins are mad expensive to
Old Sep 17, 2010 | 01:47 PM
IDNC76's Avatar
Dont even mention the Body lift, your just making it more confusing. BL will not effect the suspension/ struts you want.
Those Rancho struts you mentioned in your first post are for 4" Lifts, you have a 2.5 leveling kit. you need struts for a stock height truck.
Old Sep 17, 2010 | 04:20 PM
ah okay.....yeah I figured that......I know body lift doesn't move my suspension since i don't have a suspension lift lol (I do want a 6 inch suspension lift but cant afford it)
So pretty much I've figured out that I need stock Struts and Shocks (maybe even the blistein leveling ones for the front) and when I get a suspension lift, I'll need to change them up again lol fun
Old Sep 17, 2010 | 10:17 PM
what about one of these kits? http://www.4wheelparts.com/productli...0+CID+GAS&pg=1
Old Sep 18, 2010 | 12:12 AM
buckshot85's Avatar
you could always get the rancho quick lift and take off the leveling kit
Old Sep 19, 2010 | 12:46 AM
What's that? I need details on that...it was either that skyjacker which I don't want now or a Rancho 4" lift
Old Sep 19, 2010 | 01:19 AM
IDNC76's Avatar
That 3" skyjacker "kit" is basically a larger strut and aal. Most agree 3" is too much on the front end components. imho this is just an expensive leveling kit.
1) if just want new struts that will level the truck. Get the adjustable Bilsteins or something comparative.
2) if you want an actual suspension lift then do research on all the different lifts. keep in mind all the associated cost that go with it, your looking at atleast* 4-5k with this option.
Old Sep 19, 2010 | 11:32 AM
Ah well originally I wanted new struts but with the Rancho kit for $2400 it wasn't a bad deal....now I'm just worried how it would get from that to 4 to 5k?
