Amsoil
Old Sep 14, 2010 | 07:20 PM
Zbl1077's Avatar
Amsoil
Has anyone tried amsoil 5w-20? Ive heard nothing but good things about it and was wondering if its worth $9.15 a quart.
Old Sep 14, 2010 | 07:50 PM
sam1947's Avatar
I use the 0W-20 100% synthetic in my 07..had nothing but good luck with it.. I usually change it around 6 to 8 months intervals. Just make sure you use an Amsoil filter or equivalent. The XL 5-20 is more like the OEM oil..different PAO stocks I believe. At any rate, just become a dealer for $20..that 5-20 oil becomes about 5 dollars and change per Qt and you save on all the other Amsoil products in the process
Old Sep 14, 2010 | 08:55 PM
Micheal's Avatar
No thanks I will stick with the motorcraft that has been proven far more than superior for our ford engines.
Not knocking amsoil, just not willing to pay that much more for something I dont believe I would benefit from.
Old Sep 14, 2010 | 09:58 PM
bankrpt's Avatar
Well guys I ran motorcraft oil and motorcraft filter since I bought the truck and changed the oil and filter every 3,000 miles and when I got my frpp hot rod cams installed they had to scrape the valve covers to get the build up out of the valve covers and the internals was stained they said it looked like cheap oil or I didn't change my oil regularly which I have done since my truck was new 89000 miles ago they recommended me me using amsoil oil and filter.
Old Sep 20, 2010 | 01:22 PM
The Pig's Avatar
I have been using Amsoil 0 w 20 for quite some time. The extended change interval allows me to change my oil twice per year rather than 4 times per year. The extra protection of synthetic is some assurance when it comes to extreme cold weather starting. Where I live, the winter temperatures can be as low as -30C. The additional cost is saved by doing 2 less oil changes each year.
Old Sep 20, 2010 | 04:12 PM
Amsoil 0w-20 w/ Amsoil filter.
Old Sep 20, 2010 | 05:15 PM
Dog'em's Avatar
All I use.
Old Sep 20, 2010 | 10:32 PM
greencrew's Avatar
Only if you drive a lot of miles and can extend your Oil Change Interval.
Old Sep 22, 2010 | 12:37 AM
jhartley's Avatar
I use the 0-w20 and run it with 10,000 mile oil changes with no problem i became a dealer for 20 bucks its well worth it
Old Sep 22, 2010 | 06:28 AM
REDstx06's Avatar
whats the price difference per quart when you become a "dealer," as compared to just buying it outright?
Old Sep 22, 2010 | 08:01 AM
sam1947's Avatar
It's roughly about 20 - 25% off from retail on average depending on product. If you use many products or sell to friends you can re-coup that $20 pretty quick.
Quick reference....the 0W-20W 100% synthetic oil is 10.50 per qt....dealer price is $8.10.
Old Sep 22, 2010 | 01:32 PM
bogeyrider63's Avatar
just changed my oil this weekend to amsoil 0W20 with the amsoil filter. put on about 10K a year, so i plan on running it for a year. will be checking it frequently to see how it hold's up.
Old Sep 27, 2010 | 03:55 PM
jhartley's Avatar
you save a little over 2 dollars a quart and you save on oil filters too. I also changed my tranny oil with amsoil and i saved big by doing that
Old Sep 27, 2010 | 04:16 PM
4.6 Punisher's Avatar
Not entirely true. Amsoil is probably the best brand of oil that you can buy. It's expensive, but it's the best. That's why I opted for Amsoil in my rear axle.
Old Sep 28, 2010 | 03:02 AM
The Amsoil 5w20 XL oil is pretty much a clone of standard Mobil 1, and is priced about the same - $6.95 a quart. It should be changed at 7500 miles or 6 months, just like Mobil 1 and the MC blend. It's group 3 dino based synthetic.
The Amsoil 0w20 synthetic ($9.45) and 0w30 Signature ($10.50) oils are true synthetic PAO oils and are worth every penny in my opinion - if you extend your drain intervals and use a premium filter.
