Gear oil change how often?
Old 08-27-2010, 10:54 AM
fordaholic22's Avatar
How often shound the gear oil be changed? My buddy says the oil is synthetic and is good for life
Old 08-27-2010, 11:00 AM
818F150's Avatar
no not good for life haha... I think its 60k
Old 08-27-2010, 11:41 AM
subcooled's Avatar
I think Ford says the rear differential fluid is good for life unless the rear differential has been submerged under water or is being serviced.
Old 08-27-2010, 12:35 PM
305f150's Avatar
Subcooled is right.. Also if you are leaking at all.
Old 08-27-2010, 02:09 PM
glc is offline
I did mine at 100k. Book says 150k I believe. If you have a LS, it's going to start chattering right around 100k.
Old 08-27-2010, 02:24 PM
MUD DIGGER's Avatar
wait till it chatters the oil ford used and is reccomended is 24$ a quart and i belieave are trucks take a little more than 4 quarts i know because i redid my rear in november....the gear oil is a rip off if you ask me
Old 08-27-2010, 04:19 PM
glc is offline
You can buy full synthetic 75W-140 for a lot less than that - no more than $15 a quart. $24 sounds about right for full list price for Motorcraft lube at the dealer.
The 8.8 and 9.75 rears take 5.5 pints (less than 3 quarts) and the 10.25 rear in the 7700 package takes 7 pints.
I don't know how much the LS additive is at Ford, but that's the stuff you should use.
Old 08-27-2010, 05:53 PM
Blue07STX's Avatar
75w140
I paid $17.50 per quart at the local Ford Dealer last week and $4.00 for Friction Modifier.
Old 08-28-2010, 08:30 AM
osbornk's Avatar
There is no recommendition to change it at all unless it gets contaminated. I started driving in 1962 and never changed it and never had a problem. Probably over 70 vehicles and some with 200,000 miles.
Old 10-14-2010, 07:50 PM
HamboneFX4's Avatar
Ok.. I noticed that the front of my Diff is wet. and underneath the truck it loos like it has been splattered with something.
Whats your suggestion?
Old 10-14-2010, 09:12 PM
07_FX4GUY's Avatar
Sounds like your rear pinon seal may be bad. At least that's the problems I was having when I discovered mine was going. Dealer fixed mine under warranty so not sure on cost.
Old 10-14-2010, 11:27 PM
FX4Nick's Avatar
I had a rear axel seal replaced under my extended warranty (with $100 Deductable) receipt said total cost was $230 about 50 was from the fluid they had to add
If it were me and I were doing the work I would just buy Royal Purple, no need for the friction modifier if you buy that
Old 10-15-2010, 05:39 PM
HamboneFX4's Avatar
Thanks Guys.. I plan to do this tomorrow and hopefully get time to take pics.
Old 10-15-2010, 10:32 PM
FX4 Matt's Avatar
Registered User
Did mine at 80K and it still looked new, and that gear oil aint cheap either I used the Royal Purple.
Old 10-16-2010, 06:24 PM
Labnerd's Avatar
Depends on the rear axle in the truck. A standard axle will never need to be changed unless it gets exposed to extreme heat (unlikely) or contaminated. I've got trucks on the ranch with standard axles with almost 300,000 miles on the same fluid and it doesn't need changing. If you have a limited slip axle- different program. You should be changing it every 30,000 miles. Not that the fluid breaks down or anything. The issue is the alcohol based friction modifier that is used with the oils. The modifier will absorb moisture out of the air and corrosion is a possibility. If you live in a high humidity area like along the ocean, lakes, etc, you need to be aware of this.
Quick Reply: Gear oil change how often?
