Vibration
Vibration
Hi,
For the past few weeks now i've had a slight to moderate vibration which only occurs after driving for 10-15 minutes. The vibration shakes the entire truck(2004 f-150 screw) and shakes the steering wheel, it also gets worse when the brakes are applied. Prior to the vehicle warming up there are no vibrations at all, it only seems to occur after the vehicle has warmed up. Any help at all would be appreciated, thanks!
it could be a dragging brake when it starts to do it pull over and give it the feel test and the hot one is the culprit and don't burn yourself also check your e-brake to make sure its releasing all the way.
