Is there a "Window Grease"? :-)
Old Jul 28, 2010 | 09:48 PM
Cuz's Avatar
Cuz
ALL four of my windows in my 06 SCREW "skretch" when I roll em down. Is there any kinda lube or any other way to make this stop? Driving me ********** nutz!!!
Old Jul 29, 2010 | 12:13 AM
Watson91's Avatar
There is a silicon based spray you can get at any autoparts store. Just tell them what you are wanting and they should be able to direct you to it. Comes in an aerosol can with the straw attachment like WD40.
Old Jul 29, 2010 | 02:43 AM
The window grease is right next to the blinker fluid.
Sorry, couldn't resist.......
Old Jul 30, 2010 | 11:15 PM
Cuz's Avatar
Cuz
lol knew that was coming! Kinda what it reminded me of when I thought of window grease.
Thanks Watson. I'll try that!
Old Jul 30, 2010 | 11:17 PM
4x4wolf's Avatar
My 05 is doing it too and its so freakin annoying
Old Jul 31, 2010 | 12:13 AM
Tailrace's Avatar
Same here with my '07
Old Jul 31, 2010 | 02:11 PM
06bluemeaniexl's Avatar
having the same problem here too...
Old Jul 31, 2010 | 10:23 PM
Tailrace's Avatar
Anybody ever cure this problem?
Old Jul 31, 2010 | 11:04 PM
avfrog's Avatar
So does mine... I believe it is the tracks that squeak, and you probably have to take the door panel off to get to it.
Old Jul 31, 2010 | 11:07 PM
1sheltie's Avatar
I have an 04 that had this problem. I took the door panels off and sprayed the tracks with Dry Lube. You can also use the on the felt window tracks. This is a spray can like WD40. I got this from the dealer and it is made by Kent
Old Aug 1, 2010 | 12:50 AM
Cuz's Avatar
Cuz
Mine is for sure the windows making this noise as they slide down...
Old Aug 1, 2010 | 04:19 AM
Watson91's Avatar
Yeah, best bet is to just spray the window. I took my whole door apart and cleaned everything and still did, i ran to autozone picked up a $4 dollar can gave it a quick squirt and haven't had a problem for about a year now.
Old Aug 1, 2010 | 12:55 PM
HiVoltage14.4's Avatar
what did you use?
Old Aug 1, 2010 | 12:56 PM
avfrog's Avatar
And you sprayed to window??
Old Aug 1, 2010 | 05:14 PM
Watson91's Avatar
Not exactly sure what it's called, its a silicon lubricant if I'm not mistaken. If you go to your local automotive store I'm sure they carry something and can direct you to the right product if you ask. You roll your windows down and spray the rubber tracks.
