Oil filter
Letting your oil and or filter go for more than 5k is crazy talk! Just get motorcraft filter, valvoline, mobil 1 whatever brand of oil you prefer (I use Mobil 1 full synthetic) and change em both every 3k. Ive seen way too many engines go from not changin either one often enough. Oil and filters are cheap. Engines are not.
Whatever. It's your truck, spend your money how you see fit.
You should be regretting Penzoil more than the K&N filter.
BTW: BITOG member here too.
Check your owners manual and warranty info my friend. It specifies oil change intervals up to and including 7500 miles using the sythetic blend 5w-20.
Even then, 3k change intervals are excessive. My '08 screw calls for 7500 miles, 6 mo except for extreme duty, then it's 5k and 6 mo.
Maint
I've got a 07 Heavy Half and it calls for oil changes every 3K maint, falls under the heavy duty cycle or whatever it's called today. To keep the extended warranty in effect, that's only 3 oil changes a year for me so it's better to do it than risk problems if something breaks. I also have the dealer do it so it's on record there, no questions on whether it was done or not.
