Efans from 2010 on 04-08 5.4?
The part number you are looking for is a RF-252. I will look to see if there are any pigtails for the fans yet and let you know that part number also.
The MarkVIII fan is a lot cheaper, and the DCControls controllers are great....You are looking at under $200 for that setup....make your own hook brackets and the bottom attaches to the radiator support assembly....
Did you get your fan yet? If not here is a link. Look up a warehouse in your area and not a dealer, you should be able to get the fan cheaper from a warehouse. Way less than 200. http://www.fordparts.com/Landing/Motorcraft.aspx
And to answer an earlier question above...a FK50P will run both fans, I stumbled across a post where they were doing it without any problems. So we (I) wait.
