What is this for?
Old Jun 14, 2010 | 11:10 PM
aPINCHbetter90's Avatar
What is this for?
I got my new plates today and while I was changing them I noticed there is a spot where a key locks something to the right of the rear plate, what is this for?
Old Jun 14, 2010 | 11:12 PM
Titan357's Avatar
the spare tire I assume.
Old Jun 14, 2010 | 11:13 PM
Spare tire access hole. The lock is there to prevent spare tire theft. Your ignition key is the key for the spare tire lock.
Old Jun 14, 2010 | 11:50 PM
jgger's Avatar
The old ones had a lug nut style lock way inside the tube. People would loose the key or if bought used not get it at all. About 35-50 bucks to replace, this is a great improvement IMO !
Old Jun 15, 2010 | 12:50 PM
That makes sense, I was sitting there looking at it for awhile. Im glad I never got a flat so far cause otherwise I would have never know why my spare wasnt coming off.
Old Jun 15, 2010 | 01:01 PM
If you have time it's a good idea to do a practice run on how to drop down the spare and go about doing a tire change on the side of the road. You'll wish you had if you have not tried it yet.
Old Jun 15, 2010 | 04:35 PM
Titan357's Avatar
I was going to take mine out, maybe I will this weekend, I had to take the jack out to mount the amp, so why carry a spare? Ill just leave it at dads garage.
on topic, the same key that fits the spare should fit the tail gate right?
well my ign key will not fit either one.
Old Jun 15, 2010 | 04:49 PM
GTRider245's Avatar
Any roadside rescue company across the country can bring you a jack. Not so much on a spare tire and wheel to fit your truck.
Old Jun 15, 2010 | 05:46 PM
08stx4x4's Avatar
Like GTRider said, anybody can bring a jack, whether it is a AAA type services or even a passing cop who decides to stop. They likely wont be carrying a spare tire out to you though.
Your ignition key should be able to unlock any of the exterior locks on the truck. If it can't then either you're doing it wrong or the tailgate/spare lock were swapped out for a different one at some point in time. I'm sure your local dealer can get the locks fixed up or maybe even a locksmith could.
Old Jun 15, 2010 | 06:53 PM
CREWZER'S's Avatar
I KEEP MINE SPRAYED WITH WD40. Try to change one after a couple of years with rust and mud.
Old Jun 16, 2010 | 08:29 AM
Titan357's Avatar
I call dad, worse comes to worse he has to get a floor jack from the garage anyway, and thats where the tire will be. Very worse case, I load my truck up on the car hauler and he pulls my ford home with a dodge
Now if I had a freaking tool box, I could store my junk it it, I so want a black tool box.
Old Jun 16, 2010 | 12:29 PM
dilloncawthon's Avatar
why not just put your jack under one of the front seats, mines under the front seat and the tire iron and stuff is just in one of the side compartments on the rear doors.
Old Jun 16, 2010 | 12:34 PM
Titan357's Avatar
thats a good idea, but I will one day get a tool box, and put it there.
Old Jun 16, 2010 | 12:35 PM
its a good idea to lubricate the spare winch and check tire pressure atleast once a year
Old Jun 16, 2010 | 04:27 PM
SoonerTruck's Avatar
You should have just mounted your amp behind the back seat so that you cold have left the jack in place.
